It is currently Mon Aug 11, 2025 5:35 am
PostPosted: Thu Nov 24, 2016 6:32 pm
First name: Jonny
Last Name: Fifield
Its been a while since I change the paper on my open ended 16" drum sander
There is a clip of sorts at the end thats giving me grief any suggestions would be great as I am not spending another 2 hrs trying to do this minimal task
gurrrrr
"Practice enough till the results aren't hopes but expectations" forum member Peter Havriluk
PostPosted: Thu Nov 24, 2016 8:09 pm
First name: Heath
Last Name: Blair
City: Visalia
Mine came with this tool and it's way more useful than I thought I would be.
sweat the small stuff.
These users thanked the author Heath Blair for the post: Jonny (Sat Nov 26, 2016 1:18 pm)
PostPosted: Thu Nov 24, 2016 9:06 pm
Paper changing is something I checked-out before buying my drum sander.
A big reason why I got a Supermax 19-38.
With pre-cut strips, 2 minutes to change. Fast and easy.
Brent
These users thanked the author bftobin for the post: Bri (Fri Nov 25, 2016 10:34 am)
PostPosted: Thu Nov 24, 2016 9:15 pm
Last Name: G
That looks like it has the same end clips as my General 24" drum sander. A pretty fair summary of how the spring loaded clips work is here :
http://www.general.ca/pdf/machines/15_s ... 50_ENG.pdf
It starts on page 17.
Trimming the end triangle like they show helps. I have a strip saved so that when I use bulk sandpaper I can use it as a pattern to get the length correct.
cheers
These users thanked the author SteveG for the post: Jonny (Sat Nov 26, 2016 1:18 pm)
PostPosted: Thu Nov 24, 2016 9:42 pm
That is the most irritating feature of that sander. With my old hands and the tight spaces I have given up and tape the inboard end of the belt onto the drum with cellophane or strapping tape (all the way around the end of the drum). After the new belt stretches I retape it. Even when using those stupid clamps I have had the belt come loose and the end of belt get chewed up to where it is too short to reattach. Again - tape is your friend, and can allow you too use an otherwise good belt.
They should call it a 14 1/2 - 29 inch sander. [headinwall]
It is an otherwise O.K. machine with a reasonable cost/ benefit ratio.
These users thanked the author Clay S. for the post: Jonny (Sat Nov 26, 2016 1:18 pm)
PostPosted: Sun Nov 27, 2016 3:42 pm
First name: Jonny
Last Name: Fifield
The last time I changed it ,I thought the clip would pull out towards the motor,making it easier to slide the paper in.
I don't remember needing 3 hands lol
Users browsing this forum: No registered users and 41 guests
